Fuel line big enough?
Old Jan 26, 2016 | 08:41 AM
1969's Avatar
Default Fuel line big enough?
My car is an original 6cyl car if that makes a difference and I'm wondering if the line from the tank is big enough to support a 725hp motor?
Old Jan 26, 2016 | 12:52 PM
flat tire's Avatar
the 396/375 came with a 3/8" line
my engine builder said I need at least a 3/8" line for my 532 horse small block.
so to answer your question ........ no
Old Jan 26, 2016 | 03:34 PM
1969's Avatar
So i guess the next question is how hard is it to replace the stock line with a bigger one. I havent looked up under there before. Do you have to drop the tank?
Old Jan 26, 2016 | 04:12 PM
flat tire's Avatar
yes drop the tank and get a new sending unit
Brand:OER
Manufacturer's Part Number: 6428845
Part Type:Fuel Tank Sending Units
Product Line:OER Fuel Tank Sending Units
Summit Racing Part Number:OER-6428845
Fuel Pump Included: No
Quantity: Sold individually.
Notes: Single 3/8 in. line. Includes lock ring and rubber gasket.
you can get one with a return line depending on your intensions
1969 Chevrolet Camaro New Aftermarket Fuel Sending Unit - TNKFG104D
$62.07
$107.38
  • Part #:TNKFG104D
  • Manufacturer Part #:FG104D
Description
  • Condition: New
  • OE or Aftermarket: Aftermarket
  • Manufacturer: Spectra Premium
  • Number of Outlets: 2
  • Ohms: 0-100
  • Inlet Size: 1/4 inch
  • Outlet Size: 3/8 inch
  • Features Included: Fuel Sender, Float, and Strainer
Old Feb 1, 2016 | 11:27 AM
bruce69camaro's Avatar
What size line do you plan to run from the tank up to the motor?
I'm going to be builder a 600+ motor and I have a #10 line coming from my cell to the fuel pump and then was told to run 1/2" up to the regulator and 3/8" line to each fuel bowl.
KJW468
67-69 V8 Tech
Jul 22, 2013 01:10 AM
manslaughter299
Jul 24, 2012 03:17 AM
2tirefire
Aug 12, 2011 07:17 PM
96ZLT1
Jul 13, 2010 04:51 PM
SpecterGT260
LS Series Tech
Feb 22, 2009 12:22 AM
