Flywheel Question
Old Apr 25, 2009 | 06:18 AM
14wntr's Avatar
Default Flywheel Question
Is an aluminum flywheel worth the added expense? I am currently doing a full rebuild of the 350sb in my 67 and am building the engine to approx 420 hp. How much difference does it really make? Are there warping issues to contend with down the road? I am using a Centerforce II clutch.
Old Apr 25, 2009 | 04:39 PM
It depends on you and what you want. A lighter spinning assembly means less horse power eaten by the engine itself. So more power to the wheels. The down side is a heavier spinning assembly means more power is stored when you rev the motor. So at launch you will have more torque coming out of the hole.
We ran aluminmum fly wheels on out circle track car along with aluminum Drive shafts. Not all Alumi fly wheels are equal. You want a nice thick steel insert to avoid warpage. So buy a name brand you trust. Another issue with this setup is time. If the car sits a lot you can get a reaction between the steel and aluminumum. This can slow down the transfer of heat. I am not talking one or two years but if this clutch sees little driving in say ten years it could start to show a problem.
Old Apr 25, 2009 | 08:03 PM
greenarrow's Avatar
September 2009 ROTM
I just bought a ram billet/steel flywheel off Jegs and it was only 340 I believe for my car. Not to bad a price for what it can do for you.
Old Apr 25, 2009 | 09:07 PM
jagass's Avatar
It depends on you...
Old Apr 26, 2009 | 01:16 PM
14wntr's Avatar
thanks for the help, I will be sticking to the iron version for now.
BigCat2010
Sep 9, 2013 11:24 AM
mike6208
Feb 3, 2012 01:12 AM
Lilspleen
Nov 10, 2011 10:45 AM
endo
Sep 30, 2010 12:51 AM
osu_2010
Mar 27, 2009 09:37 AM
