Fiberglass or metal fender?
Old Nov 28, 2011 | 11:36 AM
deezz2nuts's Avatar
Default Fiberglass or metal fender?
I am begining the restoration of my 1968 Camaro coupe and need to swap out the fenders. I have been looking online at various manufacturers such as (Unlimited Products UP22.com etc..) which is the best quality fender or would i be better off with a metal fender?
Old Nov 28, 2011 | 11:46 AM
Fiberglass fenders/front end would work ok as long as you're installing a roll cage to tie the front subframe to the body. The metal fenders, being bolted to the body and frame, actually gives the front subframe some rigidity to prevent up-flex. Fiberglass fenders won't give the same strength, they can crack instead.
xxSithRagexx
82-92 V6 Tech
Feb 28, 2015 12:57 PM
1980rscamaro619
Feb 29, 2008 12:25 AM
PrinceCharmmin
Aug 12, 2005 12:02 AM
