Engine wiring
Old Jul 28, 2013 | 09:28 PM
valijean76's Avatar
Default Engine wiring
Hello-
I am replacing the wiring harness on a 67 Camaro. This is the wiring harness towards the passenger side, the one that feeds into the wiper motor, solenoid, etc.
The previous wiring was so jury rigged, I am having a hard time figuring out where to run the wires. In particular, how do I run the wires from the fuse panel to the solenoid and coil? The solenoid is right beside the exhaust pipes, so I am looking for the right approach to avoid those.
Pictures of how others have done it with OEM harnesses would be greatly appreciated.
Thank you
Ryan
Old Aug 11, 2013 | 08:49 PM
6t9sscamaro's Avatar
The harness is fed over to the passenger side using the wiring harness gutter that is screwed to the bulkhead in the center of the engine bay.
Using this gutter: Camaro Firewall Wiring Gutter, 1967-1969 - Ricks Camaro Parts
then it is held in place on the lower heater box stud by a retainer: Camaro Firewall Wiring Gutter, 1967-1969 - Ricks Camaro Parts
there is a retainer that goes on the solenoid to keep it in place so it doesn't get burned by the exhaust: Camaro Wiring Harness Retaining Clip, Starter Solenoid, 1967-1969 - Ricks Camaro Parts
I hope that help you some.
Old Aug 20, 2013 | 01:28 PM
Sorry, posted the wrong part for the clip that goes onto the heater box stud. Here's a good link for it: Camaro Clip, Firewall Heater Box Wire Retainer - Ricks Camaro Parts
Old Sep 8, 2013 | 09:16 PM
valijean76's Avatar
Thank you, that is very helpful
Old Mar 17, 2014 | 10:03 AM
Gator1967RS's Avatar
I have a issue with ignition system and was trying to find a good wiring schematic to help me track down the issue. I haven't been very successful. Do know you, or anyone out there, where I could find one. I'm converting it to electronic ignition so this would really help me out.
Tomg303
Nov 7, 2012 09:04 AM
ed1380
Apr 21, 2010 09:48 AM
bizarre660
Dec 29, 2009 07:17 AM
carpenterkyle
82-92 V6 Tech
10
Oct 29, 2009 05:27 AM
