Electrical question
Old Jul 29, 2022 | 11:04 PM
Rick1955's Avatar
Default Electrical question
I have a 1967 Camaro six cylinder . The issue I’m having is when I turn on the headlights both turn signals light up green and there are no dash lights, signals work, brakes work, back up lights work any ideas?
Old Jul 30, 2022 | 05:42 AM
Everett#2390's Avatar
Either a bad ground of cluster to dash or miswire of cluster connector.
Old Jul 30, 2022 | 10:59 AM
red42's Avatar
Rick,
I'd guess it is a bad ground. Whether you can find the problem spot or not, I'd run dedicated new ground wires from a solid Ground to the dash and the headlights, on top of any existing ground wires already there.
Old Jul 30, 2022 | 11:20 AM
Rick1955's Avatar
Default Electrical issue
Thanks red42,
I think it’s a grounding issue, I replaced all the bulbs during the restoration and found grounding problems with the tail lights and corrected those, could it possibly be the headlight switch?
Originally Posted by red42
Rick,
Old Jul 30, 2022 | 08:11 PM
red42's Avatar
Thanks red42,
Rick,
Not likely. Other than ground wires, I do not think there is any connection between the headlights and the turn signal indicators.
Jward6222
Apr 23, 2018 04:59 PM
Danlp1
Feb 25, 2017 02:50 PM
UFGatorFan
Jun 21, 2012 11:50 PM
Po' Boy
Jun 12, 2012 08:42 AM
Parrish
Sep 13, 2009 08:30 AM
