Door hinge spring
I just used mine on an 84 Camaro to replace hinge pin. Open it as wide as it will go and beat it into spring with hammer. It will compress enough for spring to come out. Be careful with it after spring is out though, don't want that sucker flying out. Worked like a Champ for me, once you use it you will never have problem doing hinge pins again
