Cowl induction air cleaner
Old Oct 12, 2013 | 04:37 AM
1bad's Avatar
Default Cowl induction air cleaner
I have a 1969 Camaro with a 350, I bought a cowl induction air cleaner from Classic and the back of it hits the larger electronic distributor.
I needed about a 1/2" more, I thought about taking a hammer to the back of the air cleaner cover, but I have no metal work knowledge.
I sent the cowl induction unit back, I still want a cowl induction.
Any suggestions?
Thanks
Robert
Sun City West AZ.
Old Oct 12, 2013 | 08:22 AM
Too bad you sent the air cleaner back already, you lost your opportunity to check measurements, unless you already took some. The one you had is made to clear the stock distributor, not an HEI. If you don't have a hi-rise intake manifold, you should be able to use a 1" air cleaner spacer to raise the base above the distributor cap, one like this: http://www.summitracing.com/parts/aa...6086/overview/
Old Oct 12, 2013 | 02:44 PM
deez28's Avatar
Yep, I second Camaro 69. Can't use the HEI distributor.
Old Oct 12, 2013 | 03:50 PM
Smee78's Avatar
Also always take pictures, it always helps to measure and use your camera.
Old Oct 12, 2013 | 09:17 PM
Glenns-67SS's Avatar
Don't they make a small cap hei--there is a Guy that does or used to --Bing Daves small body hei's --then it would work--i have the hood but the cowl set up is to spendy for me i just use the K&N lid!!
Old Oct 12, 2013 | 11:14 PM
Guys have made the conventional HEI distributor work, either with an air cleaner spacer, or with a hammer to the back edge of the air cleaner base. The distributor you're talking about (Daves) isn't an "HEI" like we know them, not a coil in cap style but a separate coil type. For the $200 he wants to convert a points style distributor over to electronic, I think I'd buy an MSD unit instead. But, that shouldn't be necessary, he just needs to create a little more clearance.
Old Oct 13, 2013 | 12:03 PM
1bad's Avatar
Default Thanks
Yeah, I sent back the unit too fast.
I think that 1" spacer will work
Thanks.
Swiss
67-69 V8 Tech
Aug 16, 2010 12:50 PM
sewerman64
Nov 5, 2009 05:24 PM
mikes77camaro
Aug 28, 2008 01:32 PM
91CamaroGuy
Oct 29, 2007 06:00 PM
hateandanger
Dec 11, 2006 09:13 PM
