Convertible top fuse mounting.
Old Apr 25, 2021 | 11:21 AM
JeffB's Avatar
Default Convertible top fuse mounting.
Does anyone know where the fuse for the convertible top mounts. This is a thirty amp fuse the factory assembly manual shows bolted to the firewall but I can't find the mounting holes. It is wired to the horn relay and then through the firewall to the power top switch and back to the pump.
I found some photos from before the re-paint and can see the mounting location. The painter must have welded the holes shut prior to paint. For anyone else with the issue - the fuse mounts to the firewall to the driver's side of the dash plate with the option codes by a couple inches.
/M3
May 31, 2023 07:22 PM
Jward6222
Apr 7, 2018 04:48 PM
CagJ201
Jun 6, 2010 11:55 AM
ncbaby72
Jan 9, 2009 04:09 PM
gotalcoholmanup
Mar 1, 2008 07:00 PM
