coil questions
Old Jul 12, 2024 | 06:49 PM
vsj100's Avatar
Default coil questions
Mine is a 68 Camaro with a 427. The distributor is an older Unilite with a new module. I recently had a very old Mallory coil 29219 fail. I had an older Bosch coil at the shop that I installed and it worked. Today I installed a new Edlebrock coil PN 22739. The engine fired right up and runs and sounds great. Do any of you see a problem with these parts playing well together?
Thank you as always!
Scott
Old Jul 13, 2024 | 06:22 AM
manicmechanic007's Avatar
I see no problem using the Edelbrock coil
Old Jul 13, 2024 | 08:41 AM
SoCal67's Avatar
Does the Unilite Dizzy spec a OHM rating for the coil it requires?
Old Jul 13, 2024 | 10:10 AM
vsj100's Avatar
Mallory (holley) said that the 29219 is correct. Hopefully the ebrock is close.
Old Jul 14, 2024 | 03:01 PM
SoCal67's Avatar
yeah they are both 1.4 ohm coils
Old Jul 14, 2024 | 03:37 PM
vsj100's Avatar
So far so good. Today I test drove it. Made it home. At hi rpm it did flutter a little. Got to work that out.
Old Jul 15, 2024 | 01:33 PM
vsj100's Avatar
Default Coil wire with cloth cover
Is the wire with the cloth cover going to the coil a resistor wire. 1967 camaro
thanks,
Scott
Old Jul 15, 2024 | 02:31 PM
Yes, that is the resistor wire
Old Jul 16, 2024 | 02:45 PM
SoCal67's Avatar
Yes, if you measure the volts, its around 8
Old Jul 17, 2024 | 09:23 PM
vsj100's Avatar
Please let me know if you can solve my issue. It has to do with voltage at the coil. I removed the ballast resistor and now have the cloth covered wire going to the + coil. The dist is a Mallory Unilite and the coil is Edelbrock PN22739 Should work in place of Mallory 29219.
Things were great until today on the way home. I could feel it coming on. The spark seems to fade away after 10 miles or so.
I was able to make it home by jumping the coil with full voltage. The jumper went from the back of the alternator to the +coil.
If possible please recommend the best way to power the coil. I have not replaced the ignition switch yet.
Thank you!
