cigarette lighter fuse
Old 02-22-2009 | 11:31 AM
/M3's Avatar
/M3
Default cigarette lighter fuse
Just had to replace the fuse for the instrument panel and could not locate the fuse for the cigarette lighter. Wanted to check since its been dead for a while. Is the fuse located somewhere else because I did not see it with the rest of the fuses.
Old 05-31-2023 | 07:22 PM
CamBigCat's Avatar
it says 11 on the diagram attached to the left of the steering wheel,
but on the actual left to the steering wheel panel that u open up, i didn't see any number 11, there's a 25 on the actual fuse panel and some other numbers, but no #11
the cig fuse spot is #11
u raise a good point
my other mechanic, not my go-to-mechanic said that even if my problem was a socket problem , it's an easy fix
CamBigCat
06-03-2023 03:17 PM
VietnamEOD
08-16-2022 08:28 AM
ncbaby72
12-30-2008 09:28 PM
gotalcoholmanup
03-01-2008 07:00 PM
Pro_built7
07-22-2007 10:54 AM
Quick Reply: cigarette lighter fuse
