Can someone help me value this 69 Z28
Car is original black / black z28
Took the vinyl top off!
1969 Z28 X77 Triple Black Car
ST 69 112437 NOR 277684 BDY
TR 712 10 B PNT
02 D X77
FRESH RESTORATION ON THIS BEAUTIFUL Z28
NEW
UNDER BODY:
FULL PIECE FLOOR PAN, BRAKE LINES, FUEL LINES,NEW BODY MOUNTS, FRONT SUSPENSION,
HEIDTS 4 LINK REAR SUSPENSION, US WHEELS, NEW TIRES, REAR DISC BRAKE CONVERSION,
WILWOOD BRAKE CALIPERS,NEW FUEL TANK, NEW FLOWMASTER EXHAUST WITH STAINLESS TIPS
ENGINE AND TRANSMISSION
CHEVY 350 BLOCK BALANCED AND BLUEPRINTED PUNCHED TO 388 625HP
SPORTSMAN RACING PRODUCTS PISTONS AND RINGS MOTOWN 220 64CC HEADS PORTED AND POLISHED
CUSTOM GROUND CAM WITH A #4 AND #7 CYLINDER SWAP, POLISHED HEADERS,VACUUM PUMP
ELITE INTAKE MANIFOLD PORTED AND POLISHED HOLLY ULTRA DOUBLE PUMP 750 CARBURETOR,
EVERY THING FROM AIR CLEANER TO OIL PAN IS BRAND NEW. NEW POWER STEERING PUMP
HIGH VOLUME OIL PUMP, NEW FUEL PUMP, EVERY MECHANICAL ITEM UNDER THE HOOD IS NEW.
NEW TREMEC TKO 5 SPEED TRANSMISSION, CENTERFORCE DFX CLUTCH.
AUBURN 12 BOLT POSI TRAC WITH MOSER AXLES ALL BRAND NEW
NEW DYNA MAT INSULATION, HOUNDSTOOTH INTERIOR, CENTER CONSOLE,REPRODUCTION RADIO
BLACK VINYL TOP AND TRIM INCLUDED (NOT INSTALLED)
2 LARGE BINDERS WITH ALL RECEIPTS
TR 712 10 B PNT
02 D X77
NEW
UNDER BODY:
VTownSuzieQ
Nov 25, 2006 02:55 AM
1968CamaroFl
May 22, 2006 02:40 PM
