can anyone identify this wire?
hey, Ive caught a wire down in the foot well and pulled it out, i cant see where its been plugged into it looks the same colour wire what goes to the brake servo but everything still works fine?
![](http://i148.photobucket.com/albums/s36/p3te_2jz/DSC_0018.jpg)
![](http://i148.photobucket.com/albums/s36/p3te_2jz/DSC_0022.jpg)
![Name: DSC_0021.jpg
Size: 71.4 KB](https://camaroforums.com/forum/attachments/67-69-general-43/13885d1501207934-can-anyone-identify-wire-dsc_0021.jpg)
![](http://i148.photobucket.com/albums/s36/p3te_2jz/DSC_0019.jpg)
I believe it's the parking brake indicator wire. If you look at your last picture, between the fuse block and the parking brake, you'll see the spring loaded sensor/switch. It plugs in the bottom of the switch.
I installed n American Autowire set and couldn't fit the sensor between the parking brake and the fuse block. It looks like you had sufficient room. I'll need to revisit it. Y
