Camaro 69 X44 vs 67 RS Convertible
this is why i post here. yes, it is 350 but did not get a chance to get the engine tag for 69 camaro yet (did on RS and it is matching). i will see if i can get it. keep you posted.
For the 67 RS, I was able to get and decode the engine tag (VI22..ME) but for X44, the guy sent me a picture that look like a VIN on the engine. did they ever put VIN on 69 Camaro?
The partial VIN on the block is what makes the engine matching numbers. The last 6 digits on the VIN tag should be on the block for it to be considered "numbers matching". On that same pad is also where the engine code should be: Camaro Decoding help on Chevy-Camaro.com
The "ME" code was used on the 67 and 68 327, 210 h.p. engine, 2 barrel carb, with a powerglide trans.
so it is matching, and the guy said it is 350:
http://www.photobucket.com/1969x44
If you're referring to the LM1 option, then that would be one rare car. That was a very short lived, early production option, and most if not all were pre-X code era. This one is a later production X code car.
I don't think 27K 350's as rare.
L65 1969 Camaro Optional engine, 350cid, 250hp 2bbl Turbo-Fire V-8. Introduced Jan, 1969 to replace LM1. $21.10 26,898
Ooh, I sit corrected then. I didn't realize there were that many L65's out there. Did that info say anything about the production run length, if it ran into the X code time frame, unlike how the LM1 didn't (that's what I was referring to as rare)?
#20
I am no expert. I use these guys Welcome To The NEW Camarosource.ca - Internet's Largest Most Complete Camaro Resource Site
The only reason I knew there where non SS 350s in 1969 is becasue I made the same mistake a few years back and I was called on it.
