Books for body work on 1st Gen Camaro
Old Oct 8, 2010 | 07:35 PM
CamaroDad's Avatar
Default Books for body work on 1st Gen Camaro
Does anybody recommend any good books on replacing panels on a 1st generation camaro. I am really looking for a step by step guide to replace rear quarter panels and trunk floor. Some questions are do I need to remove gas tank? How do a remove Lead filler? Do I need to remove rear window? Any help you can offer would be greatly appreciated.
Old Oct 8, 2010 | 08:03 PM
MN_Camaro's Avatar
Check out: http://howtoasap.com/
Yes, you should remove the gas tank. Yes, remove the rear window. There is a MuscleCar episode DVD you can get that shows how to remove lead filler - I will have to look for that.
Old Oct 10, 2010 | 06:28 PM
CamaroDad's Avatar
Thanks for the link. Does anybody know how to get a set of replacment keys (ignition and door/trunk locks); or do I need to replace the locks. I do not have any keys for this car. Thanks again!!!!
Old Oct 10, 2010 | 06:39 PM
Any lock smith or GM dealership can and re-key your cylinders and hook you up new keys if you take the cylinders into their shop you will save a ton in labor.
I really like the Paintucation series. Two must watch if you are at the metal working stage is "Body pannel replacment" parts 1 and 2 and "Metal prep and rust repair" Rust repair will show you how to be 100% sure the oxidation is done. No suprises 5 year from now
http://smartflix.com/store/video/17/Paintucation-Series
GMCTIM
Apr 29, 2012 11:39 PM
JeepGuy12
May 5, 2011 02:00 AM
The Corvette Doctor
Apr 30, 2009 08:10 PM
ohiocopper12
Jan 26, 2007 06:51 PM
camaroboss
Dec 29, 2005 06:47 PM
