Big block conversion 1969 camaro
Old Jul 19, 2012 | 11:16 AM
bruce69camaro's Avatar
I'm having a hard time following this thread. Popkorn69 posted the question, then Ron Wilson reply's thanks for all the help and then mentions his install, then you have this "not so normal" reply from this Truing person........
I think I may need some too?
But as long as we're all happy, that's what matters the most!
Old Jul 19, 2012 | 03:41 PM
"Can I have some of that" may have been asking for whatever that Truing person is smoking. Share with the group!
Old Jan 19, 2015 | 07:45 PM
Randy Craig's Avatar
Default Question:
I have a '67 that has had the 6cyl replaced with a BB 402. Apparently they used small block mounts because the distributor cap is mashed hard against the firewall. How big of a job is it to replace the small block mounts with BB mounts. Any welding involved or just bolt on. I have also thought about trying a different type distributor with smaller cap to see if that will give enough room so as to not need to replace mounts.
Any feedback and/or advise would be appreciated.
Old Apr 18, 2015 | 01:43 AM
moparmusclecars's Avatar
where does one buy these big block motor mounts, to go BB from SB?
Old Apr 18, 2015 | 09:37 AM
BBC and SBC motor mounts are available at any parts store. They both fit on the same frame mount, so it's simply pulling one off, and putting the other on. The difference is simply height.
Old Apr 18, 2015 | 11:10 AM
oh, so you just change the motor mount itself, and not the tower on the subframe?
Old Apr 18, 2015 | 11:12 AM
I know there has been talking of the heater core being different and people talking about cutting new holes in the heater core case. Isn't that what this would do? Also, than a guy who just need to switch to a big block heater core, correct? Not trying to hi-jack the thread, but learn along with the poster. GMK4020379676 Nova Camaro Heater Core Case for Models with Big Block V8 New | eBay
kilroydiver
Feb 7, 2012 06:17 AM
bbcjimmy
Jul 22, 2009 05:36 PM
money3000
Aug 19, 2007 09:56 PM
jsinss69
May 14, 2006 01:21 AM
