Best Automatic trans for 496 Big Block
Old Jun 10, 2016 | 08:12 PM
moparmusclecars's Avatar
Default Best Automatic trans for 496 Big Block
What's the best automatic transmission to put behind a 496 built for cruising and some highway driving in a 67 Camaro. We were going to go a TH400 with a gear vendor, but now I am being told that that would be too hard on the 400 from the transmission experts. We want a transmission with or without electronics. Car will seldom see the drag strip, but more of a cruiser and highway driving at times. How about the 4L80e? I was also looking at the Hughes Performance Transmissions. Any advice? Gonna go with a Currie Ford 9 inch rear end with about 350 (range) gears.
Old Jun 12, 2016 | 09:34 AM
steve69ss396's Avatar
TH400's are very strong. The one in my car just has a 34 element sprag, RVMVB, and good friction materials, other than that it's stock and my car runs deep in the 9's. Put good friction materials in your TH400 along with about a 2,500 stall and a good transmission cooler with the Gear Vendor OD. I'm assuming your 496 is fairly tame. If you have a cam that is 245+ duration @0.50" you will probably need a looser converter.
This kit has the friction materials you want: https://www.summitracing.com/parts/hup-hp2288k
DUNE DICER
Jan 25, 2009 09:34 PM
junojpeg
67-69 V8 Tech
Jul 21, 2008 06:58 PM
camaro
67-69 V8 Tech
Jan 19, 2008 11:25 PM
Carinhas
67-69 V8 Tech
13
Aug 23, 2007 05:02 PM
1st_love
Aug 23, 2006 04:26 PM
