Bare Metal Coating after Stripping
Old Mar 20, 2012 | 01:09 PM
LarryD's Avatar
Default Bare Metal Coating after Stripping
Not sure if this is the right forum for this question but here goes. I have access to a couple of large tanks big enough to immerse my 67 doors to strip them with electrolysis (want to make sure I get any rust inside the door cavities). Once they are stripped, I will wash them down and dry. So, I plan to paint the outsides with DP90 epoxy primer but want to make sure the insides are protected where I can't paint. Is there a good chemical solution to "dip" the doors for coating where I can't spray and that is also good under epoxy primer since dipping will coat the whole door?
Thanks....
xxSithRagexx
82-92 V6 Tech
Feb 28, 2015 12:57 PM
cplthomas
Apr 11, 2010 11:32 AM
