Any Big Blockers?
Old Apr 21, 2012 | 09:50 AM
20yearslate's Avatar
Question Any Big Blockers?
I'm new to the forum, and Camaro 69 kindly pointed me over here. Do any of you guys run a big block? Or is everyone running small blocks? I just had a few questions about the Mark IV vs the Gen VI, mainly seeing how hard it would be to get a Gen VI up and going in a Gen 1 Camaro.
Old Apr 22, 2012 | 05:58 PM
mikes68's Avatar
i have a 1966 ss impala with a 396 and in a few weeks my 68 camaro will have a 1969 396 in it all it takes is time and a few dollars lol
Old Apr 24, 2012 | 12:30 AM
bigblockbob427's Avatar
th_4271.jpg?t=1276821303Ummmmmmm Yes I do.
Old Apr 27, 2012 | 08:49 AM
bruce69camaro's Avatar
Why yes I do, it's a 396 around 500hp.
Car originally was a 6 cylinder.
Everything to do a swap is easily available.
Old Apr 30, 2012 | 02:33 PM
blk69Cam's Avatar
I have a 454 with a M-20 going in mine. Orignally it was probably a 307 or 327. Some things depend if you have a auto or manual. I know for me I had to swap out the frame mounts, the motor mounts, and the transmission crossmember. Also I had to buy a big block transmission linkage. You would want to change your front springs out with big block springs, and if you have stock front drums I would recommend swapping to disc because of the added weight. I'm sure there would be some exhaust changes, and a bigger radiator for additional cooling. Traction may be an issue if you have a non-posi 10-bolt.
