Adding power brake booster
So I have used the Googly and searched, seen where a lot of people have added a power brake booster (to a previously standard brake car), but have not found this- is there some bracket needed for mounting the booster to the firewall? Or, does it bolt right up in place of the old master cylinder?
If you do a power disc conversion all the brackets are included. No bracket is needed for the booster itself, it bolts right to the firewall where the old master cylinder comes off. You will need a bracket for the proportioning valve which will be included in kit.
I bought mine on Ebay in a kit. It came with the booster master cylinder and bracket ready to bolt on and also included the proportioning valve and steel lines. Worked out well.
I have mine fitted with those got some nice, stopping power with the car. The car is very responsive upon braking and it works a lot easier slowing the car
