69 rear brake light issue
Old Aug 10, 2021 | 08:10 PM
Buddy1969's Avatar
Default 69 rear brake light issue
Have a intermittent driver side rear brake light issue. Basically works when it wants to. Replaced the original rear harness cleaned the ground. New turn signal switch about 2 years ago.
Had it out today, initially both brakes lights working, reverse to park ok, reverse to park to drive ok, reverse to drive ok, then reverse again then it stops working. I can go for a short drive and it starts working again. My wife pointed out it started working again after I used my turn signal. All other lights work fine.
Any ideas appreciated. Cheers!
Old Aug 10, 2021 | 09:00 PM
What kind of shape are the bulb sockets in? Might be time for new ones.
Old Aug 11, 2021 | 11:09 AM
Buddy1969's Avatar
rear harness is brand new including sockets.
Old Aug 11, 2021 | 06:00 PM
Might be that turn signal switch.
Old Aug 12, 2021 | 12:43 PM
There is not short cut here. You are going to have to wait until its not working and track down the issue. Step one, are you losing power or ground? Even a bulb can be intermittent.
Old Aug 13, 2021 | 07:35 AM
Buddy1969's Avatar
I agree no short cut. I haven't had the chance yet to see if it's power or ground. But I did run a ground wire from each of the left tail light sockets to ground and this didn't help. So I can't 100% say it's not the ground until I check it with a meter. But it is looking like a power issue. Forgot to mention I did swap the bulbs with the right side tail lights, same issue on the left side.
Aviator1288
Mar 23, 2020 09:46 AM
maxs74camaro
Sep 9, 2019 01:53 PM
tmhill79
Jul 9, 2016 08:14 AM
fastbenni78
Aug 28, 2013 05:04 PM
pcarollo
Apr 27, 2011 09:26 AM
