69 Odometer Rebuild
69 Odometer Rebuild
My 69 convertible has an odometer issue...turns over 11K miles every 1000 miles. Odometer appears to be original. Do I have rebuilt or just buy an odometer and put in myself? Thanks...Gary
11K for every 1K is pretty strange. I was thinking wrong spedo gears, but yours is off way beyond gears. If you want to keep your current speedometer, you may want to give these people a call, otherwise you could try a salvage yard.
http://www.speedotest.com/
http://speedometersolutions.com/
Sure sounds like the gear that holds back the fifth digit is stripped. Replacing the odometer is fairly simple to do, it's just held into the speedo housing with a clip. I don't know if any aftermarket companies sell just the odometer portion, so getting a used unit off ebay might be your best bet. And what mileage your car winds up with is between you and your conscience.
