69 conv. cross member
Old 11-21-2007 | 03:07 PM
REAL69Z11's Avatar
Default 69 conv. cross member
Trying to locate a transmission tunnel reinforcement plate which is only on the convertable. It looks like it is similar to the transmission crossmember but it is further back the tunnel towards the rear. This was for adding rigidity to the chassis because of no hard top roof. If anyone has a convertable and can verify this piece, it would be greatly appreciated. I believe mine is missing!!!!!!
Old 11-21-2007 | 09:43 PM
hipirn's Avatar
Default RE: 69 conv. cross member
REAL69Z11. My 67 convertible has the reinforcement plate as do all 1st gen. convertibles far as I know, anyway mine is out, I'll take a look at it in the next day or so and get back with you, but it doesn't look like a mount, it is a square shaped plate maybe 16" with bolt holes at the corners and is sculpted (not flat) a little. I've seen them advertised at some of the 1st gen. merchants. hipirn
Old 11-22-2007 | 08:34 AM
hipirn's Avatar
REAL69Z11: The convertible floor reinforcement is available new, Rick's and Camaro central list'sit for about $90.00 in an older catalog. It is skelotonized and mounts with 6 bolts... hipirn
Craig Ferguson
01-10-2015 09:49 AM
cajundude
82-92 V6 Tech
07-31-2010 09:49 PM
markbass
82-92 V8 Tech
12
06-23-2009 01:35 AM
fotoboy
12-03-2005 02:12 AM
Quick Reply: 69 conv. cross member
