68 w/o PS- How hard to add?
Old Jul 21, 2007 | 03:50 PM
sweetquads's Avatar
Default 68 w/o PS- How hard to add?
My 68 doesnt have power steering. How hard to add it? Any kits i could buy or do i have to buy all separate?
Old Jul 21, 2007 | 08:33 PM
jonnyNITRO's Avatar
Default RE: 68 w/o PS- How hard to add?
I haven't seen any kits. I think you have to buy the parts separately, I could be wrong. But, in any case, you're looking at probably $600 for all the items NEW. You need : The power steering pump, the pressure and return lines, the pulley, steering box ($300)different steering coupling joint, and the associated brackets.
It might be easier to find a used one and just replace a hose or two.
Old Jul 22, 2007 | 08:41 PM
KMausiak10's Avatar
i had a friend that wanted to convert as well.... and he couldnt find a kit so he just had to buy all the parts seperatly and i think it cost him around 700... and i agree wtih "johnnynitro" go to the junk yard and find a camaro wtih power steering a rip it all out... then just buy a new power steering pump for 70$....
Old Jul 22, 2007 | 09:33 PM
sweetquads's Avatar
What do you think of this kit?
http://www.unisteer.com/mm5/merchant...=CHEVROLET+CAM
Old Jul 23, 2007 | 10:57 AM
Blade's Avatar
June 2007 ROTM
dont. its easy to drive without
Old Jul 24, 2007 | 11:35 PM
1969 SS's Avatar
ORIGINAL: sweetquads
here's a few things to think about:
if you are looking for a simple conversion, STAY AWAY FROM RACK AND PINION!!!!! there are way to many things that you will need to change and fabricate to get it going and if you haven't really done it before, you are opening up a can of worms, never mind the possible bump-steer problems that usually have to be worked out when putting in a rack
if you do go with power steering, stay away from junkyard parts. not worth the headache and possible unknown problems.
a powersteering conversion is a simple straightforward job. the hardest part is separating the pitman arm (and that isn't that hard), but make sure you do get a new one for powersteering because they are different (there are actually two for powersteering also)
this is a perfect time to do over your frontend too. it's about $300.00 for a complete, major frontend kit, then you need to buy a box, pump and brackets
enjoy!
Tommyboyink
Oct 20, 2011 12:11 PM
Viridian1991
Jun 17, 2011 04:49 AM
Devin's camaro
Feb 23, 2011 10:11 AM
Chevy101
Oct 27, 2010 01:48 PM
rs305
May 5, 2007 02:53 PM
