68 Camaro 327 SB CAM ADVICE NEEDED.
I recently pulled the motor out of my camaro due to a oil leak. 90% sure it was coming from the Oil pan and timing chain cover. Anyways noticed that the CAM is a cheapy and would like to replace/upgrade. Looking for something middle of the road as far as street vs. drag. What should I go with as far as lift duration, etc? How would I know if I need to replace the push rods?
68 Camaro Stats.
-327 V8 Small block (0.30" boared/flat top pistons)
-202 Valves/World Heads
-Hydraulic lifters
-3 Speed Auto
-3000 Stall convertor
-Turbo 350
-12 Bolt rear end
-Power track locker rear end with 4:10 gears
-Edelbrock Performer Intake
-Thinking about 650CFM edelbrock carb
-EXISTING CAM: c1H-288-U lobe lift 320 valve lift(1.5)480 duration@.050 230 nominal 288 timing at .050 tappet rise ex. open 43 BBDC, close 7 ATDC, int open 7 BTDC,close 43 ABDC. lobe center 108.. spring 1.710 height
68 Camaro Stats.
-Hydraulic lifters
-3 Speed Auto
-Turbo 350
-12 Bolt rear end
