67 convertible ss engine swap to ls2
I was not wanting to put this engine in this car but thought I would see what you would do.
I have a LS2 with the 6 speed tranny wiring and computer. Would you put this in a 67 camaro convertible? My car does not have the original engine. It has a 400 small block in it now.
[IMG]local://upfiles/10909/F6EC033E57A04C7A946B2DA80840F71E.jpg[/IMG]
RE: 67 convertible ss engine swap to ls2
I would. Simply for the gas milage improvement you would get out of the swap. As long as you have all the proper wiring and the computer is correct for the motor you should be good. Some simple fab work might be due. It has been done before. Do a search on this site to see if anything turns up.
