67 Camaro question
Old Feb 21, 2012 | 09:36 PM
JustinA's Avatar
Default 67 Camaro question
Tonight I took my car off of the rottiserie and bolted on the subframe and rearend. My issue is the car looks like it is sitting extremely high in the back, granted I am going to add a fair amount of wieght but it appears to me there will be 7 or more inches above the tire when finished. I put all new rear springs and bushings in it oredered from napa. Was told to go with a 5 leaf spring that it would lower the rear a little and improve the ride. A little concerned I sat on the tail pan adn it only dropped about 1 inch and I weigh 200 lbs. Am I worried for nothing or am I going to have to look into lowering blocks. Right as it sits there is a little mor that 19 inches from the center or the axle to the top of the wheel opening.
Old Feb 21, 2012 | 09:55 PM
When you replace your springs, bushings, etc., you want the suspension loaded (car sitting on all 4 tires) before you tighten any bolts down for real. If you tightened down your leaf springs with the car in the air, your suspension is pre-loaded. If that's what you did, loosen the front leaf spring bolts and the rear shackle bolts (top & bottom), then bounce on the car again, and tighten it back up.
Old Feb 22, 2012 | 06:08 AM
dynarider33's Avatar
Mine looked high also when I first put the body back on the chassis. To add to above, tightening the rear suspension is the last thing you want to do . You want all the weight on the car first. It will settle some but not a lot if those are factory height replacement springs.
Old Aug 5, 2012 | 05:45 PM
John W. Harvey's Avatar
Default 69 camaro front leaf spring mounts
My question is im looking for a mount that sits on the front spring and hooks in i need a visual on this so i can weld in my mounts i just need to see what it looks like mine where completely gone so i have nothing to base it on
alexanderr
Jan 21, 2010 07:06 PM
19camaro78
Apr 22, 2008 09:57 PM
skillz
VS
12
Mar 20, 2008 02:57 AM
1986camaro2.8
Nov 30, 2005 12:17 PM
