67 Camaro Compression Vs 93 Oct
Old Mar 3, 2010 | 06:30 PM
1995Camaro's Avatar
Default 67 Camaro Compression Vs 93 Oct
What is the Highest Compression that would support 93 Octane Gas? Im building a 327 looking to get the most HP and compression Out of It.. Thanks Guys
Old Mar 3, 2010 | 07:41 PM
A lot depends on the heads you are going to use. Aluminum heads, fast burn chambers, reverse cooling, etc.. will allow more compression. Also if you use modern engine management systems, even more compression can be utilized. Back in 1968 the 350 HP Corvette 327 used over 11:1 compression with iron heads, but then premium fuel was rated 100 + octane (Sunoco 260), and cost about 35 cents per gallon.
Old Mar 4, 2010 | 04:35 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
ive got a 68 camaro with a 327 thats has 10:1 compression and ive had no problems with the 93 octane gas. ive been in it hard and up steep hills and ive never heard and detonation. i have cast heads and a aluminum intake with just a 650 edelbrock. works really good
jodisierra
Mar 2, 2011 09:19 PM
Bennyt900
Jun 1, 2007 10:22 AM
z28child
Mar 28, 2007 07:22 PM
dmacqrazi
Oct 14, 2006 09:41 PM
thirdgencamaro
Nov 2, 2005 10:15 PM
