327 V8 power?
Old Aug 21, 2007 | 01:24 PM
  #21
skar's Avatar
Default RE: 327 V8 power?
Looking good.
Old Aug 26, 2007 | 02:58 PM
  #22
racecarchris's Avatar
give it a good tune u, make sure it's timed correctly, and find a good carb guy to get it adjusted to the needs of the engine. Some folks will over tune a carb to try and get more out of it whenall it reallydoes is hurt the engine. Wheather it's origianl or not.... who cares... unlessyou are going to make it a hanger queen and show it.
Old Aug 28, 2007 | 09:58 AM
  #23
skar's Avatar
ORIGINAL: TSTONE
right now planning on sticking with the 10B and just installing a posi carrier
everything ive read has indicated that it will be fine for my HP - you still may want to consider a 12 if and when you go with your 383 setup
right now im sporting 295/50/15's out back and turning about 3500 @ 80mph
I am having the 10 bolt redone. $1100 out the door for a Alburn pro and a 3.55 gear . @65MPH would be about 3,000 RPM with my tires. They tell me it will hold up on 400HP(SAE)with street tires with a auto. (no drags) I don't have the cash for a 12 bolt($3200 made and installed) I dont run this car that hard. YET!
Old Aug 31, 2007 | 01:16 PM
  #24
skar's Avatar
DONE!
New suspension & gear. Now I can burn both wheels .
[/align] no more peg leg.
Old Nov 23, 2011 | 09:28 PM
  #25
67freeloader's Avatar
As a matter of opinion only, I'd keep everything the same if you have a matching #'s car. Proper tuning and maybe a hotter spark could make a difference. I had a "loss of power problem" some time ago with a chevy small block only to learn that the battery was not performing as required. I replaced it with the correct amperage product and surprisingly grabbed alot of lost HP.
Chevy small blocks are basic / simple machines and if internally sound, only need minor adjustments to gain maximum performance within their designated range regardless of the HP rating.
A duel exhaust system will always maximize your HP.
MaxTheKiing
Aug 23, 2010 03:21 AM
rbeard
82-92 V8 Tech
Aug 9, 2009 12:11 AM
dkblind87
LS Series Tech
Jul 27, 2009 05:35 PM
IBADRIDE
Jul 13, 2006 01:44 AM
