327 V8 power?
Old Aug 20, 2007 | 01:05 PM
skar's Avatar
Default RE: 327 V8 power?
Keep us posted on that. What RPM at 60 MPH. And what dia. tire with the 373 gear.
Old Aug 20, 2007 | 01:43 PM
cfdtd's Avatar
(TSTONE) Yeah, it is a 327 210hp powerglide. I am going to be upgrading to a 4b carb and intake soon. Which cam did you go with?
Old Aug 20, 2007 | 01:48 PM
TSTONE's Avatar
it was a comp cam - but off the top off my head i couldnt tell you which one
Old Aug 20, 2007 | 07:29 PM
wildpaws's Avatar
ORIGINAL: cfdtd
My first Camaro was a '67 RS 327/210 with a three speed which I traded in on my '69 Z/28. I upgraded the cam in my '67 to the Chevy 327/350hp one, I should have changed to different heads at the same time as well as 4v carb, but time ran out in '69 and I traded for the Z.
Clyde
Old Aug 21, 2007 | 07:21 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
ORIGINAL: TSTONE
ORIGINAL: Cplthomas
The 327 was the engine for the Z-28
the 302 was the Z motor not the 327
Here we go again. We are both right. The Z-28 came with a 302 - but, it was a 327 block with a 283 crank. I guess it wasn't a true 327 since the crank was smaller so I will conceed - you are more right.. Anyways, cfdtd, keep us posted, got any pictures?
Old Aug 21, 2007 | 07:58 AM
TSTONE's Avatar
you are correct - but the problem is that so many dont know or take the time to learn that part - so we wind up with people swearing their all original Z is an original 327/350/396/454 car
Old Aug 21, 2007 | 09:24 AM
skar's Avatar
[quote]ORIGINAL: TSTONE
Are you sticking with that 10 bolt. DTS told me if I stick with street tires and a auto that it will be fine .(beefed up new parts)
And what dia tire and RPM are you at with that 373 gear.
Old Aug 21, 2007 | 09:29 AM
TSTONE's Avatar
right now planning on sticking with the 10B and just installing a posi carrier
everything ive read has indicated that it will be fine for my HP - you still may want to consider a 12 if and when you go with your 383 setup
right now im sporting 295/50/15's out back and turning about 3500 @ 80mph
Old Aug 21, 2007 | 11:18 AM
skar's Avatar
That is some big meat you have on your car.(tires)
Old Aug 21, 2007 | 11:47 AM
  #20
TSTONE's Avatar
no rub with 4 people in the car over RR tracks on a stk suspension(no mods - spacers - coil overs)[/align][/align]If you like theold school hot rod look- they look awesome[/align][/align]15x8
3.75bs
-19os
295/50-15[/align]
