327 oil leak, can’t find!
Old 08-25-2021 | 02:44 PM
SoCal67's Avatar
use Permatex Black "ultra" RTV on the front & rear china walls. Don't use the cork gaskets. I used the Edelbrock intake gaskets 7201. Use the included metal plates to block the center heat x over ports unless you are still using the stock heat riser choke on original carb
Old 08-25-2021 | 06:49 PM
Originally Posted by 6Camaro
It was the intake manifold
Typical,that seal at the back has to be installed just right or it'll leak.
Old 08-29-2021 | 10:48 PM
The best way to install the front and rear valley seals is to throw them out. RTV is the only way to go, the seals like to squirt out and leak.
clay95z28
07-23-2016 03:54 PM
2000pewter3800
07-31-2012 07:25 PM
Turtle604
07-15-2008 05:26 PM
sp9o3
10-26-2007 03:53 PM
microkid
01-01-2007 06:03 PM
Quick Reply: 327 oil leak, can’t find!
