1968 tach issues
Old Feb 4, 2021 | 02:32 PM
TeeLu68's Avatar
Default 1968 tach issues
I’m having an issue with my factory tach. When it’s hooked up the car starts on the release for the key and when it’s not hooked up the car starts on the crank of the key. If there is anyone with any insight on what the problem and solution might be I’d be very grateful for your info. Thanks!
Old Feb 4, 2021 | 04:23 PM
This is the original Points Distributer?
Old Feb 8, 2021 | 04:01 PM
TeeLu68's Avatar
yes it is
Old Feb 9, 2021 | 05:57 AM
Everett#2390's Avatar
Problem may be ign switch as tach power is from ACC side and not IGN side.
Might hook up a test light for troubleshooting and compare results.
Old Feb 10, 2021 | 06:47 AM
I'll bet the bypass (secondary) ignition wire at the starter isn't hooked up to the coil. This gives the coil a full 12 volts only while cranking. Without it, the ignition may not get enough juice to start because the main power supply to the coil is a resistance wire, dropping voltage below 10 volts when in run mode, and way less voltage than that when the starter is sucking power. Now add on a tach to the mix...
arrocha87
Aug 3, 2019 10:16 AM
Aviator1
Jul 20, 2017 09:23 PM
14wntr
Oct 16, 2013 04:57 PM
91camarodave
82-92 V8 Tech
Dec 15, 2007 01:50 PM
ericlamb
Apr 12, 2007 02:23 PM
