1967 RS
1967 RS
1967 RS
all original
has been painted, original color
some old lady couldn't squeeze it in the garage
141,000 miles
the trunk floor has been replaced, due to rust from leaky back window
doesn't look like there were any mods
very much stock
an ideas what is's worth?
this is my dream.
thanks
all original
141,000 miles
very much stock
this is my dream.
thanks
RE: 1967 RS
I'm not sure how much a car like that would go for. On one hand its all original, but on the other hand its all original. If it runs I'm not sure $15,000 maybe? [sm=smiley5.gif] I know that leaded gas was used because the lead would help lubricate engine parts, but it polluted too much. Idk if you'll have problems using unleaded with that period engine or what. Besides if you get a 1st gen wouldn't you want to put a V8 in it?
RE: 1967 RS
The lead was used for lubricating the upper cylinder and valves. It also caused a lower combustion temperature as does a higher octane rating. When rebuilding the engines, most people replace the valves with "unleaded gas" type valves. They are made to withstand the higher temperatures without burning up.
If I were to find my "dream car", I would make sure that it didn't need more work than it was worth and start bymaking a low reasonable offer and then negotiate. Since it already has had rust damage repairs, there could be more unseen issues. $15k is alittle high for a car that needs a lot of work, unless it's a convertible or an SS.
RE: 1967 RS
ORIGINAL: The Banks
Clyde
