1967 Camaro rear 10 bolt 8.2 upgrade
Old 03-08-2009 | 08:21 PM
1995Camaro's Avatar
Default 1967 Camaro rear 10 bolt 8.2 upgrade
Im restoring a 67 Camaro. I have recently removed the rear.
The axle Code is PW 0103G.
Casting # 3894859
I did find the other # ?1208 I can't read the last # or Letter.
Im trying to Keep It close to original. With be doing some engine Mod's. Has 327.
Would like to keep rear but am concered about hp/torque. Will or can I rebuild rear to hold 373,355 gears and keep same rear and will It hold up? Thanks Guys Again
Old 03-08-2009 | 09:37 PM
Hold up to what?????
Old 03-09-2009 | 08:41 PM
1995Camaro's Avatar
Default camaro rear
I'm look at hp some were in the range of 400hp. I'm just concerned how It will hold up to the torque. I will not be racing It just show's and crusing. Will have 4sp. Thanks
Old 03-20-2009 | 01:11 PM
quadman's Avatar
That rear end will hold up fine as long as you don't dump the clutch hard too many times.
cwingert
04-18-2015 02:05 AM
1995Camaro
03-16-2012 08:44 AM
1995Camaro
04-28-2011 09:06 PM
TSTONE
09-24-2006 07:56 AM
fly767high
04-12-2006 03:09 AM
