1967 Camaro rear 10 bolt 8.2 upgrade
Im restoring a 67 Camaro. I have recently removed the rear.
The axle Code is PW 0103G. Casting # 3894859 I did find the other # ?1208 I can't read the last # or Letter. Im trying to Keep It close to original. With be doing some engine Mod's. Has 327. Would like to keep rear but am concered about hp/torque. Will or can I rebuild rear to hold 373,355 gears and keep same rear and will It hold up? Thanks Guys Again |
Hold up to what?????
camaro rear
I'm look at hp some were in the range of 400hp. I'm just concerned how It will hold up to the torque. I will not be racing It just show's and crusing. Will have 4sp. Thanks
That rear end will hold up fine as long as you don't dump the clutch hard too many times.
