10 Bolt Conversion to Posi
Old Jun 7, 2010 | 11:39 AM
Buckeye69's Avatar
That is likely an 8.2 carrier in there. I used an Eaton posi carrier and it was priced @ $398.00 from a performance shop in Knightstown Indiana in 2008.
Old Jun 7, 2010 | 08:57 PM
Originally Posted by T&GCAMARO
I am looking at converting the 10 bolt rear end in my 1967 Camaro to a Posi. Does anyone have any recommendations on a kit and what to look out for? Thanks in advance for the help!
I've had a Power Trax locker in my 10 bolt for over 15 yrs. and it works perfectly. Plus they don't require any resetting of lash or clearances. It installs in a few hours easily if you've got enough knowledge to change bearings on a 10 bolt. Just pull the axles, remove the spider gears and side gears, and install it in the place of the gears.
They run about $420 at Summit Racing.
buckmaster
Dec 7, 2007 08:00 PM
TSTONE
Sep 24, 2006 06:56 AM
