1 or 2 Piece Rear Main Oil Seal
Old Jan 4, 2019 | 07:17 PM
Jacouncil3's Avatar
Default 1 or 2 Piece Rear Main Oil Seal
I have a question, I have an 84 350 4 bolt main truck motor, can anyone tell me if this is a 1 or 2 piece rear main oil seal?
Old Jan 5, 2019 | 10:51 AM
Look at the block. A one piece rear main seal engine has an aluminum housing bolted to the block, that the round seal presses into.
Old Jan 5, 2019 | 11:07 AM
Jacouncil3's Avatar
Will i be able to see it with the ell housing on? I have a 4spd so wasn't sure of i had to remove the flywheel to see if 1 piece?
Old Jan 5, 2019 | 06:50 PM
I thought maybe you had the engine out of the car. If you're sure the block is a 1984, then you have a 2 piece rear main seal. The one piece came out in 86.
Old Jan 5, 2019 | 07:09 PM
Jacouncil3's Avatar
Thank you, I was afraid of that.
bd92rs
Dec 16, 2010 11:03 PM
1979RS
70-81 V8 Tech
Jun 13, 2009 05:19 AM
libertyforall1776
Mar 30, 2009 09:53 PM
eas69
Sep 19, 2007 11:32 AM
reallyoldguy
Mar 24, 2007 12:05 AM
