DIY Oil Change on ZL1
Old Mar 16, 2018 | 08:05 AM
clphillips72's Avatar
Default DIY Oil Change on ZL1
I'd like to do DIY oil changes on my ZL1 so I can use better oil and have that sense of accomplishment.
I'm concerned that I won't be able to use my jack stands and jack without damaging the ground effects on the side of the ZL1.
My jack stands are similar to these...
https://shop.advanceautoparts.com/p/...rm=jack+stands
And my jack is similar to this one...
https://shop.advanceautoparts.com/p/...earchTerm=jack
I don't really feel comfortable using a ramp because I'm afraid I'll somehow shoot past where I needed to stop and high center my car with the ramp.
Old Mar 16, 2018 | 04:36 PM
Everett#2390's Avatar
Why not got a length of 2X12 and make some wood ramps three layers tall?
Use a 2X2 for the end for a stop and carriage bolt the 2X2 onto the three-layer ramp.
Cut the ends at 45° and drive up onto the ramp?
Old Mar 18, 2018 | 04:58 PM
Thats actually a great idea and I think that’s exactly what I’ll do. Thanks for the suggestion!
Old Jul 12, 2019 | 06:34 PM
promethius's Avatar
Get yourself some jacking pucks, like the ones ZL1Addons sells. You can get also get very similar ones for about half the price on Amazon.
https://zl1addons.com/collections/camaro-jack-lift-pads
Amazon Amazon
Get yourself some hockey pucks, Amazon sells them as well and use the puck between the jack plate and the lift pads. It will give you about 1 inch of clearance from the panels on the side.
Lemireart
Apr 17, 2018 08:10 PM
James119
Dec 7, 2017 04:56 PM
James119
Dec 6, 2017 09:11 AM
Skylane765
May 7, 2013 07:48 PM
libertyforall1776
Nov 4, 2011 03:11 PM
