Do they make tuners for a 2010 V6 Camaro?
Basically, because the ECU controls the entire powertrain's function, any non-manufacturer modification would void the warranty. However, the V6 ECU does NOT have a flash counter. This means that if you flash a new tune, then flash back to stock, they can't tell that it has had 3 flashes done (1 at factory and 2 by you).
So, if it is a stock tune when they run a diagnostic, then they can't tell anything prior. The V8's have a flash counter, so they are out of luck. The only issue for our V6 ECU would be if you left the custom tune on when you took it in for work.
Also, Trifecta recently did a new dyno test and revised their tune to be able to add 13 HP at WOT at the top end. This also smooths out the entire power curve, so you get a double improvement, even to a stock car with no modifications.
qwThis is discussed at bowtiev6.com and camaro5.com at length in the V6 tuning sections.
Just wanted to post to let ppl who were looking into this but had doubts.
Email is sevatrifectatuning@yahoo.com if any questions
Thanks
9434V6
North East
03-21-2013 09:51 PM
