2010+ V6 Tech discuss modifications to the all new 3.6L v6 here.
Bank 1 misfire
Old 12-18-2018, 06:47 PM
Jr90's Avatar
Default Bank 1 misfire
2010 Camaro v6, misfires from bank1 according to my scanner. I have switched all coil packs from side to side and it stayed on bank1. I have a bluetooth scanner that can clear codes and when I do it clears up right away and runs better. I'm at a loss, if it was a major issue it wouldn't clear up by just clearing codes.
Old 12-20-2018, 12:22 AM
Sure it would. When the check engine light is on, in your case of a misfire, the engine is put in reduced power mode, also referred to as limp mode. There are a number of things that can cause a misfire... bad coil(s), spark plugs, fuel injectors to name a few. One other possibility is due to the very nature of your engine. Yours is direct injected, and that type of engine is more apt to get greater build up of carbon on the valves because, fuel is not running past them like with a throttle body injected engine. If your car has a good amount of miles, consider taking it to a reliable shop and have them perform a GDI (gasoline direct injection) cleaning service. It's about a 2 hour process that deep cleans the the engine, and de-carbons the valves. We have had numerous direct injected cars come through our shop, running like crap and setting off misfire codes, where this service alone would totally clear up the misfire issues.
Old 12-27-2018, 05:24 AM
Jr90's Avatar
I was told that it has 2 dead valves. Any idea what would cause that and how to fix it?
Old 02-01-2019, 11:33 PM
Al Loyrat's Avatar
The 2 dead valves are probably the intake valves with carbon build up from crankcase ventilation which is what Camaro 69 is referring to. Welcome to direct injection.
SpecterGT260
02-16-2013 01:09 PM
knscharf
09-18-2011 03:31 PM
maverickrjd
09-17-2010 09:54 PM
golfballs
08-02-2008 02:02 PM
JKEpps
06-25-2007 12:13 PM
Quick Reply: Bank 1 misfire
