won't start
Old Nov 8, 2023 | 12:42 PM
schem's Avatar
Default won't start
My 2010 camaro will not start. came out one day turned the key, nothing. How do I know if it the clutch safety switch or the starter? everything else has power.
Old Nov 8, 2023 | 02:22 PM
I do not know the new cars very well, but in most cases there are 2 wires going to the starter. One is the big one from the battery and there is a smaller one. If you get power in the smaller one and nothing happens then its the starter. If you are not getting power to the starter while trying to start it then it is something else. This would require someone to try to start the car with the clutch pushed in. That is not limited to the clutch safety switch. on modern cars I think there is a signal from the Body Control Module that need to power a relay and that is on cars built in 1996. You would need a schematic or a trouble tree to figure it out. I assume if the battery does not have enough voltage the system may not even try to start.
Check battery and connection first.
RamzaFreak20
Sep 16, 2011 09:27 PM
xXChipXx
Jan 20, 2011 11:54 PM
JTyler
Aug 31, 2007 10:21 PM
evilhaserrors
Jul 18, 2007 11:40 PM
b1keslddr
Jan 29, 2007 12:58 AM
