Traction Control and ABS not working
Old Nov 19, 2017 | 05:22 AM
HWoods57's Avatar
Exclamation Traction Control and ABS not working
I have been searching the forums and checking with as many people as I can but have not been able to find a clear answer on the ability to run staggered outside diameter wheels on a 2104 gen 5 Camaro.
the information I have been able to gather has been explained that the outer diameter of your front and rear wheels needs to match in order for your traction control and ABS computers to operate properly.
I am trying to gain confirmation on this and find out if there is a tolerance that must be respected or if there is a possible ration that can be programed.
Hoping that some of you have either seen heard or found a way to make it possible to have larger diameter meat in the rear than the front. I am not familiar with the inner workings but it seems that there should be the ability to enter a direct relation to the computer to calibrate the system and allow for the difference.
if anyone has any info please share...
thank you all
Angelo1912
Apr 6, 2015 08:17 PM
97redcamaro
Nov 30, 2009 08:06 PM
Combat_Chuck
Apr 19, 2008 11:03 AM
Rs Camaro Kid
Jan 7, 2008 04:45 PM
EggboaT
Apr 19, 2007 04:48 PM
