Reduced engine power
Old Mar 27, 2025 | 11:37 AM
Loy88's Avatar
Default Reduced engine power
I have a 2011 V6 RS Camaro that runs good but every once in a while, it starts to miss and run, rough smoking and reduced engine power message comes on I can disconnect the battery for a while reconnected in the car does fine for a little while then it does it again. This has happened for five times any help is greatly appreciate First time Camaro owner
Old Mar 30, 2025 | 03:20 PM
You need to pull codes. It can be so many things. Even with the codes you need to figure out if the code is a result of the issue or the cause. In that year range I am used to the low power message having something to do with the drive by wire system but I would want to see all the codes before doing anything.
John Harvey
Jun 29, 2021 01:59 AM
Billie Walton
Apr 5, 2017 03:08 PM
NEW_CAMARO_OWNER
82-92 V6 Tech
13
Dec 7, 2008 06:54 PM
wvblair
82-92 V8 Tech
Oct 11, 2007 01:40 AM
