VERY LOW POWER?????
Old Nov 16, 2008 | 03:53 PM
NEW_CAMARO_OWNER's Avatar
Default VERY LOW POWER?????
ok, so i just bought a 1985 camaro sport coupe 2 days ago when i bought it it ran great i was driving around for a couple hours...parked it for about 1 hour and then when i went to start it nothing in the carturned on...we tried jumping it and it didnt work so i just left it at his house..... wen i called him the next day he said he got it started but now it has almost no power at all!!! he never told me how he got it started.....why would it not have power any more??
Old Nov 16, 2008 | 06:02 PM
Saint_Ali's Avatar
Default RE: VERY LOW POWER?????
whats the voltage at the battery ? what do you mean no power ? like electricity or power as in when youre driving ?
Old Nov 16, 2008 | 07:19 PM
MadMikeZ28's Avatar
Possibly a problem with the charging system and it is running off the battery. Not enough juice and it will run poorly.
When you jumped it did it crank at all and no start? Or no crank at all?
More specifics please.
(Just PLEASE no huge long lasting post for my brain to decipher)
Old Nov 16, 2008 | 07:33 PM
Saint_Ali's Avatar
yea us cmro guyz dun lik 2 read
Old Nov 16, 2008 | 07:41 PM
MadMikeZ28's Avatar
Well a picture is worth a thousand words and I much rather look at pictures!
Old Nov 17, 2008 | 09:41 PM
~~power as in horsepower
~~just put a new battery in less than an hour ago (still having problem) (12.78v)
~~when i jumped it nothing happened (no crank/no interior lights)
~~charging system as in-altinater??
~~i reached down to the (positive) wire going to the starter and yanked on it and it was loose (waiting till engine cools until i tighten it)
~~P.S... i tried to break it down cause i tend to drag on my sentences...sry
Old Nov 17, 2008 | 10:02 PM
1990CamaroRS's Avatar
Fancy Sparkle
same problem i had, stripped terminal wire bolt. i ghetto rigged mine and now it works (i also found that if you turn the cable straight down it causes a good contact with the battery)
Old Nov 17, 2008 | 10:55 PM
~~ok i just went to tighten up the (positive)wire running to the starter......the bolt/ and agood size chunk around it broke off.....could that be a possible reason why im losing power ((horsepower))
Old Nov 17, 2008 | 11:46 PM
Saint_Ali's Avatar
could be...and a fully charged battery is at 12.8 v so what you were getting is fine
Old Nov 19, 2008 | 05:10 PM
n8_camaro_92's Avatar
maybe you have multiple problems... as for the battery it could be the alternator or a bad starter... as for the horsepower check the plugs and plug wires... my grandmas car had the plug wires shorting out and when it got dark she tried to start it and you could see sparks flying all over lol
