Radio cutting in and out
Old May 15, 2016 | 09:38 AM
Captrob's Avatar
Default Radio cutting in and out
I know the 4th gen camaro's had a problem with the bcm causing the radio to cut in and out. Does this also apply to 5th gen? My daughters 2010 radio constantly cuts in and out.
Old May 15, 2016 | 11:31 AM
only thing common with 4th and 5th gen is name. oh and both burn gas,,, all i can think of. lol. is it just the radio or does cd/ipod also cut out?
Old May 15, 2016 | 11:34 AM
Captrob's Avatar
Radio cd and Bluetooth cuts out.
Old May 15, 2016 | 12:06 PM
did a quick search, try taking fuse for sub out. if not that radio was problem. couldnt find a fix but did find a few posts on the issue. dealership replacing radio seemed to be the fix found on most.
Old May 15, 2016 | 01:47 PM
Captrob's Avatar
Pulled the amp fuse and the radio completely cut off.
Old May 15, 2016 | 06:00 PM
i have a feeling the radio is the problem. wish there was more info available.
Old May 16, 2016 | 07:52 AM
Captrob's Avatar
I'm picking a new radio this morning and hopefully that will fix it.
Old May 16, 2016 | 06:24 PM
Captrob's Avatar
Well put in a new radio and it was still cutting in and out and the rear driver side speaker was still thumping. Guessing now it is the amp so tomorrow I'll swap out the amp and see if that fixes it.
Old May 16, 2016 | 06:34 PM
woh that was fast, you must be using a local pick and pull
camarorider96
Jul 7, 2010 10:27 AM
gwtexas
Apr 22, 2008 09:49 PM
BAN WS6
Sep 12, 2007 01:45 PM
Billy
Jul 17, 2007 10:26 PM
andrius
Mar 1, 2007 01:10 AM
