New car - need to clear some faults
Old Feb 24, 2018 | 09:01 AM
Monty1362's Avatar
Default New car - need to clear some faults
Hi guys
I've just bought a 2012 SS model, the 100k service has been completed before the sale but there are a few minor fault codes that I need to clear.
I have one of those Bluetooth OBD2 devices and downloaded the chevvy app and have discovered the following fault codes:-
P0422 - Evaporative Emission Control System Leak Detected Small Leak
P0522 - Engine Oil Pressure Sensor/Switch Circuit Low Voltage (this may be the reason the oil pressure gauge doesn't work, but operates when the engine is switched on)
There's also a Service airbag warning light on the dash and heads up display which shouldn't be an issue, but the OBD doesn't pick up this fault code.
Just so that I can go into the garage prepared, would anyone be able to help me out with part names and/or numbers please?
Thanks in advance
Monty
hodads
Jul 2, 2017 03:08 PM
chrisearly
Aug 4, 2012 11:37 PM
illumastar
Dec 1, 2006 09:02 PM
Blade
Oct 1, 2006 03:12 PM
