front end noise
I have a 2010 v6 and the front end has a thud when i hit bumps in the the road the dealer says everthing is tight, says i am just hearing the suspension move, any body else hear your front end move? thanks
I don't have a 2010 Camaro to compare with, but any car hitting a big enough bump will bottom out on the suspension snubbers and cause a thud. Your car uses very low profile tires which give little cushion and are by nature noisier and allow more tire thump to transfer to the rest of the car.
