Catalytic converter replacement
Old Nov 11, 2019 | 12:14 PM
camarolvr11's Avatar
Unhappy Catalytic converter replacement
So my car’s check engine light came on two days ago. I brought it to auto zone and they diagnosed my car with the codes showing the catalytic converter is bad. I dont want to go through a mechanic for the part, because it will be an arm and a leg, so i would rather buy the part myself. Anyone on here bought a catalytic converter and had the mechanic install it? Also do i need one or two of them? I currentky own a 2011 LT camaro
https://www.buyautoparts.com/buynow/...ed/45-47435_1D
found this online... will it fit under my car?
Old Nov 11, 2019 | 04:09 PM
Everett#2390's Avatar
Visual inspection will dhow if you need two or not..
If you need one, you'll need the other side
OBD II should have told you which one.
NorthernCrew454
Apr 14, 2011 11:30 AM
sgtdupree
Jan 7, 2011 08:30 PM
FearThisInc
Oct 10, 2008 08:39 PM
94Z28interceptor
Dec 3, 2006 02:13 PM
superZ
May 5, 2005 11:40 AM
