Add fog lights
Old Nov 28, 2024 | 10:55 AM
HandOverFist's Avatar
Default Add fog lights
Recently purchased a 2011 LS that did not come with fog lights. Can anyone describe what parts are needed (other than the lights themselves)? Is the harness in place or is that something else I would have to source? Thanks in advance for any information.
Old Nov 29, 2024 | 11:28 AM
Found this... https://www.gen5diy.com/collections/...-light-harness States that this will only work with OEM fog lamps...not aftermarket.
Old Dec 5, 2024 | 04:38 AM
Dogmeat's Avatar
I bought an aftermarket set of fog lights, as my '11 also did not come with the car. The kit I got had everything needed to install...I just had to take out the stock "inserts" that came with
the car, and install the kit. I was in a hurry when I installed them, and just wired the power from a fuse in the fuse box, which does NOT allow the lights to go off when you turn the
engine off....so I put the "manual" switch under and to the left of the steering wheel. So far I have only forgot to turn off the switch a couple times, but I did so before they ran the battery down...I WILL re-route the wiring so it WILL allow them go off when the switch is turned off...I think!!
If you want info as to where I ordered them, send me a text to 260-243-1113 and I'll get it to you....don't have access to it right now.
Old Dec 5, 2024 | 07:12 AM
Thanks - I'm going to wire them to come on and turn off with the head lights.
james brann
Feb 18, 2022 09:44 AM
jonss
Jul 20, 2013 11:38 PM
FRANK121
Sep 10, 2010 09:26 PM
New2Camaro
Jul 29, 2009 05:59 PM
3.4CamaroCDOG
Mar 14, 2008 08:58 PM
