2023 Camero SS order
Old Jul 10, 2022 | 09:24 PM
Preemo's Avatar
Default 2023 Camero SS order
Anyone have info or updates on NEW 2023 builds? Had my order in since late April but its still waiting on GM to accept the order.
What does that even mean?
Old Jul 15, 2022 | 11:41 AM
joelle king's Avatar
Welcome to the forum hope you get your order soon
Old Jul 15, 2022 | 11:51 AM
23SS's Avatar
Question 2023 Tuner
I have a 2023 SS on order. Dealer placed the order last week on GM order work bench. Was told may take 6 months, depending on when the factor picked up the order. He told me if they had not picked it up in two weeks, he would run it through their larger Chevy dealership. The dealerships have no control over this. As soon as it arrives I plan on adding headers. My question is, what is the best tuner available to reprogram after the header install? Its there a chip available to plug in that will take care of this?
Old Jul 15, 2022 | 01:04 PM
You should wait a year. You want to be sure there are no factory defects. The dealership can reject your warranty if you modify the fuel management system. In fact they can black list the car if they want to be ****** about it, That would mean even if you returned the car to stock your warranty is gone. Even other dealers can not get warranty work approval once the vin is tagged. I worked at a dealer and I have seen it done. In most cases the dealer I worked for would look the other way but if the car developed any issue with fuel management or spark management and it had been modified by anyone but us they would say bring it back stock. Changing the position of the o2 sensor can effect how the car runs. You can not beat a good tuner and your car on the dyno.
Most aftermarket tuners will want to be sure there software will be ok in any new model year. I suspect ones that work in 2022 would work in 2023 but you just can not be sure.
Looks like the Camaro will be the only tune-able GM car in 2023. GM did not spend the money to upgrade to the newest electronic due to the line shutting down in a year. This is also why the Camaro is not getting the newest magnetic ride or the new LT5 motor in the ZL1.
Tuning for headers is not really needed unless the header company mover the o2 sensor far away from where the factory positioned it. As a general rule on these modern engines the exhausted manifolds are designed for the application. Unlike old cars they are not stealing a bunch or power. Headers may add a little HP at wide open throttle but the factory has already richened up the fuel at wide open throttle so there is not much you can do. Real chips are a thing of the past (early 90s). Tuning the computer is the only options. I am sure you will be able to find a hand held tuner that will say it does tuning for headers. But your best bet is to catch a tuner at a show and get it tuned on the dyno on the spot.
Old Jul 15, 2022 | 01:45 PM
23SS's Avatar
Thank you for the valuable information. Will take your advise.
DEVIL DOG
Jul 5, 2022 11:55 PM
BasicConcepts
Jun 15, 2010 02:32 AM
edog2
Jun 7, 2010 07:25 PM
TrammelZ28
Aug 13, 2007 08:56 AM
nokeman
LS Series Tech
Jul 13, 2005 01:08 AM
