2015 LS99 Rough Idle?
Old Sep 25, 2017 | 08:00 PM
muffins4all's Avatar
Default 2015 LS99 Rough Idle?
I just bought my first Camaro, upgraded from a Dodge dart. I've noticed that it has rough idle when I'm at a stop sign. Tachometer hangs out around 500-600 rpm but it jumps a little. Is this normal for the LS99? I've seen it may be normal in the LS3's. It's still under bumper to bumper warranty, should I take it in? *edit* Happens in warm weather, doesn't get much better after the car warms up.
Car Info: 2015 Camaro 2SS LS99 (auto) w/ 30k miles.
An unrelated issue too, I hear a rattling sound from the exhaust when it shifts. Is this just what the stock exhaust sounds like? Sounds kind of like swirling a marble in a tin can.
Thanks!
Old Feb 4, 2018 | 12:59 PM
ricksza's Avatar
Don't worry about the idle, if there was a problem, the CEL would be lit. The rattle could be any number of things: heat shield, exhaust pipe out of position, broken baffle in muffler.
simplyfast
Oct 20, 2016 07:57 PM
mark0006
Jan 28, 2015 05:55 AM
csmiddy
67-69 V8 Tech
Dec 9, 2012 10:12 PM
CJ51974
Jun 1, 2009 08:59 PM
Bonnie w/2000 v6 called Roxy
Apr 4, 2009 03:19 PM
